Hello there peeps,,
I am having strange problem with this notebook. Sometimes I am not able to turn this notebook on again. Only for a second the leds lid and then I am having the WIFI LED flash like for 5 times ,, sometimes only for 3 times. After maybe 5-10 minutes later I am able to power it on again.
I have thermal cam and I have noticed when I plug the notebook in on the picture circled red you will notice TPS51125A which will heat up. When the power on failing I can see that it is getting cold again and after few seconds 3-5 later it will heat up again.
Could this be the problem ?? As there is no schematic not really sure what to check. Thank You in advance...
Flashed the BIOS with new BIOS and CleanME thinking that it will solve the problem but same thing was happening. Also was starting the board without the board where the switch is in case that is causing the problem. Same result ...
