PWM Dimming Control Signal low voltage drop LA-E841P
    JEDP pinout LA-E841P:
    4,5 MLO (Main-Lane)
    7,8 AUX (Auxiliary Channel)
    9,10 VCCS (Power Supply +3.3V)
    11 HPD (Hot Plug Detect)
    15 LED_EN (BL_ENABLE Signal of LED Converter)
    16 LED_PWM (PWM Dimming Control Signal)
    19,20 LCD_VCCS (BL Power)
    Have an issue with pin 16 (PWM Dimming Control Signal): low voltage drop!
    Any help would be much appreciated!
    Re: PWM Dimming Control Signal low voltage drop LA-E841P
    LED_PWM(INVPWM) comes directly from SOC. Attach schematic if you have one for better understanding. There can be way out but you will loose brigtness adjustment control.
