Bad Caps on a GE Power Control Board Refrigerator
    Here is the story....>>>
    Tuesday of this week I got a text from some good friends of my son
    We had a really bad thunderstorm that came throught made the power go ON and OFF a few time .....>>>
    Well after the power came back on for good the Refrigerator would NOT turn back ON and run
    This is one of the newer models that has a micro controller that controls everything
    This Refrigerator is DEAD no LIFE other than the light in side the frigate part and the light in freezer
    So took a look at the control board and what do I see is a TOP246YN offline IC switcher on this board and a BYW29-200G UL fast 200 v 8A Diode and two caps next to the Switcher IC one was a 47 uf no ESR value at all 1 uf 50 ohms that is not a misprint
    Replaced the IC switcher and the Diode and the two caps
    Put the control board back in the Refrigerator and everything came back to life
    BTW this control board retail for $190.00
    I got all the part from Digi-key for $15.00 and ordered 3 switcher IC and 2 diodes It took about two hours pull these parts and change them because they coated the board with what look like hot glue
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Bad Caps on a GE Power Control Board on a Refrigerator
    You forgot the most important thing! What brand were the caps that failed?
    Muh-soggy-knee
      Re: Bad Caps on a GE Power Control Board Refrigerator
      It took a little while to find the box that I had put them in
      The brand name of the two caps are the same
      Ltec SM 85*C 4601D this was on the caps
      The other caps on the board were different brands I did not change them because of all the hot glue on this board
      9 PC LCD Monitor
      1 Dell Mother Board
        I know that this is a very old post but I recently talked to the person that I had fixed his refrigerator and he told me that it was still working good after this repair
        9 PC LCD Monitor
        1 Dell Mother Board
          I have seen this many times, it was likely just the power being turned off that it did not turn back on. As long as power is applied, the ic's vcc stays up, even with the 47µf being very low. But when the vcc cap is that low it will not charge up and start the ic again. Ask him to unplug the fridge for 5 min and see if it starts back up again.
            That is what I had done before I came to the conclusion that there was something wrong with the controller board
            9 PC LCD Monitor
            1 Dell Mother Board
