Powerhouse Horizon 1208 Powered Mixer - No speaker output
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this Powerhouse Horizon 1208 here.
    The mixer appears to work - I get output on the headphone socket, but no output on the speakers. The speakers are tested working, I don't get any hiss, power on 'bump', nothing, nada
    Problem is I don't know if I have set all the controls correctly so this could be a phantom fault AKA user error or it could be faulty. I tried to find a user manual but couldn't find a download that actually worked.
    I made a quick 2 mins YT video to show what is happening/not happening - hopefully someone could check that out and let me know if this is faulty or not.
    https://youtu.be/4FfrzLJv1uU
    Cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    Re: Powerhouse Horizon 1208 Powered Mixer - No speaker output
    first off plug into channels 1 and 2 ..pan one left and other right .. m1 m2 might be for monitors
    are there any switches on the back ? and any chance of pics to see the switches ?
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Hi petehall
      Here are some pics
      The mixer is supposed to have some fault, but Domingo at Powersound speaks only 'some' English I only speak 'some' Spanish so we generally communicate in a mixture of Spanglish and gesticulation.
      As I understood what he was saying it has some problem with the speaker output on one channel, but that could be a mistranslation
      I will try channel 1 & 2 as you suggest.
      • petehall347
        • Jan 2015
        • 4424
        • United Kingdom
        you could also try plugging into line ins . and maybe the pgm button needs pressing to route the signal to the amp .
        not sure what the footswitch is about . maybe just for effects . make sure nothing is jammed in it anyway .
        • petehall347
          • Jan 2015
          • 4424
          • United Kingdom
          another thing is the mixer i have been working on was doing strange things with the led,s .turned out some were bad so changed them all .
          oh and another simple mistake is not turning the speaker plugs to lock them in place .
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Hi Pete
            I'm not sure what you meant by plugging into Line In - that's where I have my two Phono to 6.3mm Mono Jacks plugged in on stereo channel M1
            If I press the 'Listen' button in, on M1 channel, then the LED bargraph responds regardless of the Red Left/Right slider position - even if they are set to zero
            When 'Listen' is out I then have control of the LED bargraph using the M1 volume slider and the Red Left/Right volume sliders. So the above video is with 'Listen' button out
            Yeah I know how to plug in a Speakon connector but thanks for mentioning it
            On the Speakon connectors my speaker wires are connected to +1/-1 which would be the 'normal' way to connect them. The fact I don't get any turn on 'bump' or hiss on the speakers makes me think the amp just isn't running though it could have a circuit to stop the 'bump'
            I think the pgm button is for the programmable reverb but yeah I'll give it a go
            I guess the other thing is to open it up - possibly it is obvious where the audio out feeds from the mixer section to the PA section and I could use my scope, or just inject audio there from another mixer (non powered) that I have.
            • petehall347
              • Jan 2015
              • 4424
              • United Kingdom
              looks like aux ins next to record ? if there is it should bypass the channels . although signals must be getting to the main sliders or the led.s wouldn't light .
              pgm is normally out to speakers .
              be easier if there is a manual for it .
              it should be pretty simple and modular inside like all my mixers .
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                I found the fault on one of the Amplifiers. It is on the board that switches the -44V/-88V as this is a class G amplifier. Basically i had fuses blown on -44V/-88V on the left channel, plus two short circuit diodes (1N5404 + BAT20) and an iffy looking transistor on that board. At first I thought the voltage switching transistors were short, but they are not, they test OK on my Peak DCA55, it was the diodes short.
                The iffy looking transistor is B1186A shows as a 'PNP Digital Transistor' on my Peak DCA55 but the datasheet says it is just a regular PNP power transistor. This is the driver for the voltage rail switching transistors on the negative side. I'll ask about that in the general electronics/component forum section
                I still didn't determine why I had no audio but the customer said he did have audio that was bad on one channel so obviously he knows how to use the mixer and I don't LOL
                Here is a video showing what I did to diagnose the fault if anyone is interested to watch
                https://www.youtube.com/watch?v=XgZSxWMKuxc (part 1)
                https://www.youtube.com/watch?v=kbPynpQefz8 (part 2 - the fault diagnosis)
                • dicky96
                  Dynacord PowerMate 600 Powered Mixer - Protect Light On
                  by dicky96
                  Hi guys
                  I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
                  As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
                  I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...
                  05-22-2022, 04:36 AM
                • enn15c
                  SubZero SZ-PMIX8-MP powered mixer
                  by enn15c
                  Hi... trying to fix my sons SubZero SZ-PMIX8-MP powered mixer.... Initial fault turned out to be output amplifier TDA7293... but I've replaced a couple of times, and just generating more smoke!!... Can't find any fault on the power module, starting to wonder if its the mixer sending faulty voltages? So, the question.. Anyone know where I can find schematics for this unit... Google search hasn't uncovered anything obvious. thx
                  02-12-2023, 04:11 AM
                • Phlox321
                  Yamaha EMX 2000 Powered Mixer issue
                  by Phlox321
                  Hi All
                  I have a yamaha emx 2000 powered mixer im trying to repeair.
                  the problem is that theres no sound output on the right channel. Left channel works fine.
                  Right channel has output when using the phono(headphone output) but not when going through the amplifier
                  the left peak meters work but not the right
                  the clipping light however does come on when gain is turned up same as left channel
                  What i have done so far is make sure that the supply voltages are fine, which they are
                  I found several cracked solder joints on the amplifier board which...
                  10-19-2022, 11:45 AM
                • Felipe_Serra_83
                  Request for Phonic powerpod 1860 plus powered mixer service manual and/or schematics
                  by Felipe_Serra_83
                  Model: Phonic powerpod 1860 plus
                  ​Board: pod1860 v11 master pcb
                  (number above this): 0D02005Q0100G
                  I attached photo of the specific board which I need to check.
                  Thanks in advance, guys/gals. ...
                  08-28-2024, 05:08 AM
                • Bektronics
                  Schematic Digital Audio mixer RCF type M18
                  by Bektronics
                  Hello dear audio friends.
                  I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                  The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                  I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                  Thanks in advance if anyone can help me with this schematic.
                  Of course, all information about this digital mixer and possibly references...
                  07-24-2023, 06:40 AM
