Surface 4 Pro BIOS locked
    Re: Surface 4 Pro BIOS locked
    peste thanks for responce,,,,,,,,,totally dead with this file
      Peste likes to do it the hard way
      Try this.
        same with this file also
          Then your own file is faulty or you have soldered improperly.
            ori file was good and surface was turning on just after flashing bios its dead now
              help me to unlock surface pro 4
              can someone help me to clean password this dump bios
              surface pro 4
                Re: help me to unlock surface pro 4
                Originally posted by wajdi.hamed
                Aly one
                try..
                  Need Help to dump Surface Pro 4 Bios
                  I am trying to dump the Bios of my daughter's Surface because the UEFI is password protected and I can't reinstall it.
                  I am using the command fptw64.exe -Bios - d Surfacebios.bin to dump it but I have the error:
                  Error 201: [FPTw64.exe] cannot be run on the current platform.
                  Can I use it on Surface Pro 4?
                  Thank you for read me.
                  Katsubaya.
                    I make a backup with CSME System Tools v11 r40. I join a zip of my backup. If someone can help me to find UEFI password you save me.
                      My Dear Helper,
                      Please help me remove UEFI password and its corruption.
                      Initially, it boots to UEFI asking for password. After trying hard way, it stops booting.
                      sp4_i7
                        Please help. I need a dump file without password
                        Updated info: surface pro 4, 1724, i7, 16GB ram, w25q128fv
                        Attached is my corrupted and password locked dump file
                          Re: surface pro 4 bios locked
                          anyone can help me to solve my dump with surface touch issue and surface me problem, SURFACE PRO 4 1724,I5
                            Help...Remove password BIOS Surface Pro 4
                            Hello friends I need a copy of the bios for microsoft surface pro 4 to remove the bios password, I attached a copy of the bios with password so someone can remove the password, in the forum a colleague uploaded a bios without password but it does not work With my team, I hope you can help me.
                              Re: Help...Remove password BIOS Surface Pro 4
                              try..
                                Originally posted by peste View Post
                                try..
                                Keep asking for the password friend, the password has not been deleted.
                                  Code:
                                  BRAND:         Microsoft Corporation
                                  MODEL:         Surface Pro 4
                                  SERIAL:         05497556XXXX
                                  ME VERSION:       11.0.15.1003
                                  FD VERSION:       V2/3
                                  BIOS VENDOR:      Microsoft Corporation
                                  COA KEY:        N2DT8-MP229-QTC7W-3DG48-XXXXX
                                    Help me please
                                      Originally posted by KingBonecrusher View Post
                                      Code:
                                      FD VERSION:       V2/3
                                      thanks
                                        try..
                                          My Dear Helper,
                                          Please help me remove UEFI password .
