Asus KB typing without keyboard installed
    Hi Im having a issue the KB connection might have a issue but no corrusion is present .
    If the unit is started it key pressing the arrow down.
    It's my first time having this kind of issue hope someone can guide me where to look at..
    MB: ASUSX551MA REV 2.0
    Re: Asus KB typing without keyboard installed
    is this with and without the keyboard connected
      This is without the keyboard sir
        check on connector what pins of connector is shorted between them, or corosion damage
          1. Clean the connector with IPA and a brush and dry with hot air at low temperature.
          2. Check for corrosion as previously mentioned.
          3. Check resistors/resistor network near keyboard connector if present.
          4. If you are comfortable doing it, de-solder the keyboard connector and test again.
          5. Replace SIO.
          6. Get a priest
