Dell Inspiron-31533158-7353-7359-7568-Cottonwood MLK-14275-1
    here is the dump for Dell Inspiron-31533158-7353-7359-7568-Cottonwood MLK-14275-1
    Enjoy
    Re: Dell Inspiron-31533158-7353-7359-7568-Cottonwood MLK-14275-1
    thanx
      Thankx
        Hy all i have a laptop model : dell 13-7359 - p57g002 2in1 with touch screen in service and i manage to make his bios , i don't find it anywhere , i will share the program that i find for extracting the Dell Bios from an exe file and the bios , for editing the bios i use HXD Editor and Intel (R) Flash Image Tool. Version: 11.8.79.3722 - for spliting the bios in 2 parts 8mb and 4 mb , i hope will help someone , thank you all .
          hi every one, i get a question about the files posted here, if i have a one dell 13 7359 but dont work the touchscreen, i mean, the SO is W10 and i has update the drivers and BIOS and can't make to work the touchscreen. When i turn on the computer and i enter to BIOS for run a diagnostic, the touchscreen not work. I think what the touchscreen would have to work in the BIOS because is native rigth? so.. i can use this files to update the BIOS?
            Enjoy
            thanks!
              thank you my friend is working
                  Need bios repair
                  dell cottonwood mlk mb 14275-1 pwb tffrc
                  dont have service tag etc
                    Originally posted by OKRPKCOMP View Post
                    Need bios repair
                    Inspiron 7353 2-in-1
                    Service Tag: 299MD82
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      Thanks sir for quick responce
                      bios is working, display on
                      but in bios setup i cant change options value, even there is no password
                        Try this new file.
                        Service tag if you need it: 299MD82
                        all donations are welcome,
                          Originally posted by hardware1 View Post
                          Try this new file.
                          Thank u, will check tomorow morning
                            Bios is working
                            but problem is nearly same as before
                            when i add service tag in bios setup and reset the pc, it again require serice tag
                            and manufacturing mode is not off by alt-f
                              thank you allz
                              problem is solved by getting bios from somewhere else
                              Express Service Code: 4913920370
                                Sir can u solve yours bios file error ???
                                unidentified system
                                  unidentified system
                                  Try
                                    Try
                                    Thank you sir for quick responce
                                    still display comes out, but system is unidentified
                                    but i cant change anything in bios setup, even usb or hdd not boot
                                    even in security there is no password,
                                    Will u 1 try more pzzz???
                                      Try oldest version ,Version 1.2.0, A01.
                                        not working
                                        turns on, no fan spins
                                        No display and after a minute turns off
