Hyundai 22" LCD Monitor Model: X224W
    Hi, my first post here.
    I found this forum while I was searching a solution for my problem with this monitor.
    I have this monitor for some time, and yesterday when I went to turn on the pc monitor only turn on for a fraction of time and goes to sleep mode.
    I already have changed all the caps, without success.
    The power board is ilpi-033
    Any help to find the problem will be welcome.
    Re: Hyundai 22" LCD Monitor Model: X224W
    Your initial guide and help is here,follow where you can and advise,and we will help no doubt.
      Does LED stay green when it goes to sleep mode?
        The light goes from orange to green and orange again.
        I have tested the major components and all seems to be good.
        But tomorrow i will take out some components for a better test.
          Can you check with a signal. My friend's Hyundai X93W does the same and it works. With a signal it stays on.
            What signal?
              PC input going into the monitor. My friend's monitor would show "NO SIGNAL" then turn off 2 seconds later with no PC input, but it just went to standby, it wasn't a fault, it was by design.
                Now i feel like an idiot, i have tested always without signal and assumed he was still in faulty, because he only give a flash.
                But now the power board make a high voltage frequency noise, this may indicate that there is still a problem with the board?
                Thanks for the help!
                  If the monitor works, the whining sound can indicate bad capacitors, or it can indicate the glue on the inductors has dried up.
                    Hello friend! My be anybody have firmware for this monitor? I am repair this model, cpu(scaller NT68665HMFG, ILIF-072 1, Rev.B (491541300100R). CPU was be replacement, but firmware into chips lost (cpu dead).
