Dell Inspiron 15-3542 2beeps porblem
    hi friends
    i have Dell Inspiron 15-3542 with 2beeps problem
    mb Wistron Cedar 13269-1
    i try to change the ram and clean ram slot and reflash bios with ok tested one
    but with no result
    pl4902 1.35v
    dm1 -ram slot volts(with ram)
    pin 204 vtt1 = .675v
    pin 199 3.4v
    pin 30 DDR3_DRAMRST# 0V
    R410 PIN1 1.35v
    pin2 0v
    it is fault cpu ?
    any help please
    thanks
    Re: Dell Inspiron 15-3542 2beeps porblem
    What is resistance to ground on pin30(dramrst#)?
    Check resistance of R410.
    Also check continuity between pin2 of R410 and pin 30.
      Q1201/1202 working?? Most of the time its not cpu fault. have patience, this can be solved.
        resistance to ground on pin30 is 0L
        r410 is 0.47k ohm ok and there is no resistance to ground (0L) on both side
        thanks friend
          q1201
          D 5V OK
          S 1.3V
          G 1.35V OK
          Q1202
          D 1.35V OK
          S 1.35V
          G 5V
          thanks for help
            Check Q1801. What is voltage on PCH_SMBDATA (pin200 on ram slot) and PCH_SMBCLK (pin202)?
            Do you have a bench power supply? If yes, what is current draw when board is on (with and without RAM)?
              q1801 all pins 3.3v
              ram slot pin 200 and 202 3.3v
              thanks
                Something is wrong in ram circuit only. You need to check full ram requirements as per schematic.
                  ok
                    problem solved by reflash bios with file extracted from dell website by machine service tag
                    thanks for Spider1211 & mcplslg123 and thanks for all
