hello everyone I have an Asus X555LD Rev 3.6 motherboard on a notebook violently slammed into the ground. detached PU8101 and does not heat more '. I think it is broken but what I would like to know for now is how can I find the values of the capacitors, resistors, etc. of the elements of the motherboard? i downloaded BoardViewer but i can't find the values for example of PR8116. is it a resistor? what is its value?
Asus X555LD Rev 3.6
Re: Asus X555LD Rev 3.6
hello everyone I have an Asus X555LD Rev 3.6 motherboard on a notebook violently slammed to the ground. I unplugged, unsoldered PU8101 and it doesn't heat up anymore. I think it is broken but what I would like to know for now is how can I find the values of the capacitors, resistors, etc. Of the elements of the motherboard? i downloaded BoardViewer but i can't find the values for example of PR8116. is it a resistor? what is its value?
Originally posted by mcplslg123 View PostPR8116-RES 200K OHM 1/16W (0402) 1%
CYNTEC/RR0510S-204-FN. Its clearly mentioned in boardview.
boardview? another question the pin 19 of the PU8101 is short-circuited the same refers to PR8116 which has the other ground contact
is it normal that pin 19 of the PU8101 is grounded? I think not because the diagram says that 5 volts should arrive at that point. ?
Originally posted by martha februarini View Postyou can't find component code on where ? motherboard or boardview ?
if u mean component code on motherboard, many asus board don't have it.
on boardview, you can click on the component, see right panel. there's component code
