I'm working on LG power supply where I'm not getting any voltage on the board. I'm getting fluctuated voltage from 12v-15v on C103 on primary side. Also getting voltage fluctuations on pins of IC101. I replace all ceramics on primary side however same issue. Also tested mosfet Q101 looks good. Can some one tell me whats going wrong here?
LG32LN5300 No standby voltage no power
Re: LG32LN5300 No standby voltage no power
It's EAY62810301 Power Supply for LG 32 inch LED tv. C103 I'm getting fluctuating voltage on C103 is 100uf 50V which I already replaced and IC is SC1S311.Last edited by anupkg1985; 09-28-2020, 12:36 PM.
This may be the power supply schematic
Have you disconnected the mainboard from the power supply and used a 1K resistor between standby 3.5V and PWR then checked the voltages at the output?Attached FilesLast edited by dick_barton; 09-28-2020, 12:45 PM.Willing to help but I'm no expert.
It looks like SC1S311 is attempting to work but failing so trying again which is probably why the voltage is jumping around.
Here is the data sheet for SC1S311.
I would be checking that there is no physical damage to the IC and next check the components around it.Attached FilesWilling to help but I'm no expert.
