lenovo 320-14IKB no power
    Hi this board has no power if I plugged the charger but If I put voltage over the P2 section it will power on the unit , I already change the PQ6414A (pq201) but it wont pass the voltge to the pin 3 ,
    those the PU201is faulty ?
    how can it be identified?
    Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=116545
    Last edited by SMDFlea; 06-08-2023, 08:34 AM. Reason: Renamed thread title,added schematic link,added images to badcaps from external host
    Re: lenovo no power
    What is the voltage on PU201 pin 28 6 4 6 5
      Re: lenovo no power
      You need to measure BQ24780s pins specially ACP/ACN/ACOK/ACDRV/ACDET/VCC/REGN/PMON/ADP_I pins.
        Re: lenovo no power
        First check if PQ202 is shorted drain/source/gate.
          Re: lenovo no power
          pq202 not shorted from pin 1 and 4
            Re: lenovo no power
            pin 28 20v
            pin 6 2.8v
            pin 4 1.3v
            pin 5 no voltage
            pin 1 1.5v
              Re: lenovo no power
              Originally posted by kalilinux25 View Post
              pin 28 20v
              pin 6 2.8v
              pin 4 1.3v
              pin 5 no voltage
              pin 1 1.5v
              ACDRV is low PIN 4 1.3V it should be arround +22V above & PIN 5 ACOK +0V what is the voltage on pin 24 BQ2478 check PC214 for any fault & PR202/206 ?
                Re: lenovo no power
                SORRY but id fount out the big problem it created a shorted on its board direct short to be exact, its not in the component problem now, its a trash board , but thansk fotr the help every one, Gob Bless .
                  Re: lenovo 320-14IKB no power
                  my pc did not charge the battery ... and it turned on with charged battery, (with only the 19v cable it did not turn on) .. the fault was pq 201
