SUMMARY
This is a Hannspree HZ281 28" LCD monitor. It has a black screen. The power LED is green, if connected to a computer.
THINGS TESTED
1) All caps look good
2) Fuses F211, F220 and F720 on the PSU are ok
3) The connector between PSU and logic board (CN201) has +5V SB. If the computer is connected PS(ON) has 5V, but there is no voltage at pin 9 and 10 (+12V), and no voltage at pin 5 and 6 (+5V).
4) If I remove fuse F211 (which apparently connects the 12V rail to the inverter unit), I have the correct 12V and 5V on CN201. Thus it seems that the fault is in the inverter unit.
5) I removed and measured the 2 lying caps on the inverter unit (C834 and C835). My unit tester shows 1000uF and an ESR of 0. I assume they are ok.
6) There is no short blinking of the screen, if I switch it on.
PROBLEM
No power, if inverter unit is connected.
QUESTION
How could I track down the fault in the inverter unit?
THINGS TESTED
PROBLEM
QUESTION
