hp probook 450 g8 bios lost
    Hello i had problem hp probook 450 g8 was locked it has 2 chips 32mb one of theme was lost unfortunately without save the original main dump , the SN: 5CD130G3LX.
    the other dump EC :GD25Q256C@SOP16
    Re: hp probook 450 g8 bios lost
    Unfortunately the unlocking is done on the EC chip but with the condition that the original bios is kept. In the forum, there is a case of losing the original bios and everything is coming to a standstill.
    Become a Badcaps supporter
    Thanks to all supporters.
      i know this in my case the laptop has 2 bios chip 32mb first one is EC and the
      other is main so i lost the main chip without read or save the dump
      and you are correct the unlocking is done on the EC chip
      if you have any idea to resolve this or make a new dump help me please sir
        Post the mainboard number.
        I don't provide help for people using CH341A and a clip.
          i solved the problem finaly thank you sir
            How did you solve your issue? I had a bios locked 450 G8, i removed chip to read and got someone else to remove password. I flashed the .bin that they gave me to the chip and was in manufacturing mode. Then removed the chip again and was told to flash back the original .bin (which i still have). I then tried updating the bios from inside the bios via ethernet. It had 5 updates to do. On the 5th update, it said finailizing bios update, then retarted into a constant bootloop. Since that, I can no longer get it to boot anymore and it flashes 7 white on num lock, indicating bios. Any help would be appreciated.
              probook 450 g8 - not sure if programming is correct
              I have a bios locked 450 G8 (was locked actually), i removed chip to read .bin and got someone else to remove password. I flashed the .bin that they gave me to the chip and was in manufacturing mode. Then removed the chip again and was told to flash back the original .bin (which i still have). I then tried updating the bios from inside the bios via ethernet. It had 5 updates to do. On the 5th update, it said finailizing bios update, then retarted into a constant bootloop. Since that, I can no longer get it to boot anymore and it flashes 7 white on num lock, indicating bios. Any help would be appreciated.
              the 3 attached are
              1.probook 450 g8 is the original locked bin
              2.unlocked-probook 450 g8 is the .bin that someone unlocked for me from the original
              3.newprobook450g8 is the .bin i was told to flash after i explained the bootloop situation.
              the guy who unlocked for me doesnt speak the best english and i feel some sort of miscommunication mightve happend.
                Try flash the original bios
                  I have tried flashing back the original and same thing. Ill try again though.
                    HELLO, CAN YOU PLEASE HELP ME
                    hp probook 450 g8 lost BiOS
                    MB: DAX8QAMB8D0 REV D
                    SN:5CD125VMQ7
                    i have just original ec
                      SN:5CD125VMQ7
                      try
                        Originally posted by skazide View Post
                        try
                        led blinking, no power no image...
                          other one
                            other one
                            Blinking capslook 7 times
                              try. test that two and give feedback.
                                Originally posted by Blallowinformatic
                                Hello good day, need help with bios password unlock
                                HP ProBook 440 G8
                                Board: DAX8QAMB8D0 REV D
                                Chip: MX25L256736 (3.3V)
                                Prod ID 2F3X9LT#ABM
                                SN#5CD118M8DJ
                                Warranty: ly ly Oy
                                Build ID: 20WWR3CT601#SABM#DABM
                                Feature Byte:
                                3X476J6S6b7B7J7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPguk8mEn7nV.Ge
                                Thanks in advance for any help or guidance provided.
                                Oh no wrong model
                                • Vesko356
                                  Vesko356 commented
                                  Editing a comment
                                  Your off topic request is removed, use the forum search to find related threads where you can post.
