toshiba c850
    toshiba c850
    hi every one
    i have toshiba satellite c850 need bios i tried maybe 5 bios but its different
    some one working power no display some one not working i will upload original file need help please
    Re: toshiba c850
    Board number?
    I don't provide help for people using CH341A and a clip.
      Re: toshiba c850
      Originally posted by DanielDacko View Post
      Board number?
      plf/plr/csf/csr uma mb rev 2.1 pcb
      i searched with board number but all file i downloaded not working
        Re: toshiba c850
        [quote=amroo2041;1137050]plf/plr/csf/csr uma mb rev 2.1 pcb
          Re: toshiba c850
          https://www.badcaps.net/forum/showthread.php?t=56249
          https://www.badcaps.net/forum/showthread.php?t=81265
            Re: toshiba c850
            [QUOTE=satishkumar;1137100]
            thank you for your help its working
              Re: toshiba c850
              [QUOTE=amroo2041;1137387]
                Re: toshiba c850
                cONGRATULATIOSN... Dual bios
                Working ?
                Which one of the duas worked for your model?
                  Re: toshiba c850
                  [QUOTE=satishkumar;1137401]
                    Re: toshiba c850
                    Dual bios worked,thank you!
                      toshiba c850 no power
                      Hi
                      I have toshiba c850 . its was worked ok but there is password on bios . I tried programmed bios chip with a tested file but its stooped of work . I re programmed with old back up file but no power too .
                      I need for help please
                      this is old back up file
                      https://www.badcaps.net/forum/attach...1&d=1674650714
                        Re: toshiba c850 no power
                        Originally posted by aliiash View Post
                        Hi
                        Here's your Unlocked Bios, hope it works fine.
                        I think your Backup doesn't work because it was 1KB (300h) larger.
                        all donations are welcome,
                          toshiba c850 bios file
                          Hi
                          please please please I need to toshiba PLF/PLR/CSF/CSR UMA MB REV:2.1 bios bin file . I tried to programmed the chip with several different files, but all the files that I downloaded do not match the original file of the device. I would like a test file please .
                          Note : The motherboard contains only one chip. The file size is 4 MB. There is a place for the EC chip next to the main chip, but it is not found .
                          this is original bios file
                          https://www.badcaps.net/forum/attach...1&d=1674932921
                            Re: toshiba c850 bios file
                            Hi
                            Try the 2nd bios at post #4 .The single version is for win 7 ,the dual is for win 8 .You could use a 2MB chip and flash the dual ones.
                              toshiba c850-b098
                              I need bios of motherboard toshiba
                              the motherboard has just one ic bios w25q32
                                Re: Toshiba C850 PLF/PLR/CSF/CSR UMB MB REV:2.1 - BIOS
                                i need to fix this bios of c850-a965
                                motherboard plf/plr/csf/csr uma mb rev:2.1
