Default Alienware Aurora R4 bios dump request
    Hi Guys,
    I would like to request a Alienware Aurora R4 bios dump (bin/rom) , i beieve that latest bios is A11 , on the dell website it is only an exe file that i cannot extract.
    Stickers on the board say DP\N 07JNH0 Rev A02
    anybody can extract Dell bios from .Exe
    Thank you
    Re: Default Alienware Aurora R4 bios dump request
    This is the file. Try and report
      thanks to trying
      but it is not working
      this is my backup
        try this goodluck!
        There are 10 types of people in the world. Those that understand binary and those that don't.
          Originally posted by eikspaj View Post
          try this goodluck!
          If you use LBE tool to fix my info.. no work properly need to manually fix 100% work.
            Originally posted by salim.thebadboy View Post
            Hi Guys,
            Thank you
            If not work @Claudiomfa file not bios problem
              try this goodluck!
              Thank you!!!! I can confirm bios is working!
                Thank for the bios
                I Have brick the Aurora R4 when i try dell bios update.
                Wath is the bios chips on the motherboard?
                thank for your help
                    I managed to recover a Dell Aurora R4 from your A11 bios . thanks alot.
                    Although the ram slot 3 and 4 got issue, I think now the board is running fine.. Could be that i go back to R4A03, it might work, as i put in the ram tester, all data lines are fine.
                      Bricked my bios also trying to mod it for no reason, live and learn. Used the bios dump with CH341A, which is a pain to get on 100% correctly with clip. Bios did work eventually and got the machine to work again. Ram slots 3/4 however now do not work and will cause the pc to boot loop until removed and left in 1/2 only. Any ideas why it would cause 3/4 ram slots to malfunction? I have 2 of these mobos, so even if bricked again it's okay. Just trying to see if i can actually find a solution to the other slots if possible. Seems to be common that the bios causes an issue with 2 ram slots. I'm open to options. And yes I know it's a little old, but paired with a 4930k 4.1Ghz on stock voltage with the asetek AW AIO, it runs like a champ. Open to ideas, if anyone is willing. Maybe try a bios dump from my working mobo? Just trying to not brick my good board...Thanks in advance!
                        I think if you can get your original bios .bin, it might solve the problem. I measured the used ram tester to diagnose it, it seems the ram slot is good. i seriously suspect so. I am unable to get hold of the original bios...
                          try this goodluck!
                          Thanks for share! God bless you
                          It's Working
                          PC work for schemaltic:
                          Mainboard: Gigabyte Z68XP-UD4
                          CPU: I3-3240
                          Ram: 16Gb
                          Graphic Card: GTX 1050Ti zotac 4Gb Mini
                          SSD: 120Gb
                          HDD: 2Tb
