Hi everyone!
I have this wii that has no video output on composite nor on the other RGB coloured rca (forgot its name).
when i plug the power the cd reader makes noises, i can press power button it turns from yellow to green , i can turn it off with long press. If i press eject button it makes noises.
Checked the coils for voltage all are present. AVE chip gets voltages, no short on board, cpu heats up warmly. Tried pressing reset button then power, nothing happens.
Checked voltages on Y, Pb, Pr pins i get some readings but i get nothing on Composite pin.
Any idea what could be?
is there any way to low level install firmware?
Thank you
Thank you
