DA0BLQMB6E0 REV E Cannot start or powered with ram installed
    Having a hardtime beacuse no schematic is available for this modem if ram is present laptop will power for a second then off. But without ram isntalled it will run the system at 200miliamp , Ive check the ram supply resistance its not shorted checking the voltage reading has 1.3v stable..
    What can it might be the closes problem?
    I also tried a new ram and different slot
    ALL BASIC POWER RAILS IS PRESENT without the ram.
    Re: DA0BLQMB6E0 REV E Cannot start or powered with ram installed
    SIO is very likely bad . Not sure about this case but in lenovo this happens when sio goes bad.
      thanks for the good advice sir, Ill look a similar sio and try to resolder it if things change
