Noxon iRadio 300 Internet Radio server closed
    hi,
    I have this nice Internet Radio and until few days ago it worked properly.
    It connect correctly into my local net and works with Pnp features but when I select Internet Radio option it give me a connection error.
    I contacted Noxon support and they said that for security reason producer took offline server for these old models.
    From menu there isn't a way to set the URL server where the radio pick the list of channels, but I think this info its stored in the BIOS.
    Actually I don't have a backup of file BIOS but here there are still original files:
    http://terratec.ultron.info/NOXON/NOXON_iRadio/Update/
    On radio there is the firmware update option but if I make a manual check it says that the firmware is up to dated.
    Version software is: ir-mmi-FS2026-0200-0143-V.2.1.11.EX13068-83.
    Its really shame to trash a device that still works!
    Any help would be appreciated a lot. Thanks
    ps if it may help I can dismount radio a look for BIOS chip to make a backup copy of file!
    Re: Noxon iRadio 300 Internet Radio server closed
    did you install the version from the BETA folder?
    it's newer and fixes some bugs
      nope, the radio worked always fine so I really didn't care a lot about firmware and I just set to make automatic firmware update.
      I try now and I'll let you know.
        It seem that in this model its impossible to update BIOS via web interface.
        In the link:
        there is a subfolder of all models also iRadio 300 but inside there are just PDF documents.
        There is also Noxin iRadio subfolder where there are a lot of infos and also firmware updates and Bootloader so I supposed it was a folder for alls iRadio models but Noxon iRadio is a specific model.
        I tried anyway all firmware manager but my model is not compatible with it and firmware update is just trough the radio menu.
        There is also a webpage that manage Noxon devices:
        http://www.radio567.com/setupapp/rad...Err=sp1&sAuth=
        but if I enter the Mac of my radio it says is not correct.
        There is this 3rd part software:
        https://www.youtube.com/watch?v=vhyT7dAMeMM
        but I can't find anywhere the firmware of my model
          i have a noxon 300 too, noxon support said to me the same.
          did you find any fix ?
          you think this is the right forum where to post about this issue
            Same problem.
            Planned obsolescence. we should attack them :pleurs:
              i wonder if it's "normal" data and you just need to change the web / IP address to a different server??
              a router may be able to redirect that!
              i just found this on my GITHUB
              https://github.com/mr-sm1th/noxon-gateway
                I thought to replace target gateway to another within the Firmware and reflash. For this I guess u need window-enabler
                  what is "window-enabler"??
                  if you can flash the firmware then i think you may just need a hex editor
                    It takes time but you can flash a new firmware with the software they provide.
                    It is all online but you have to search for it, the correct path is http://terratec.ultron.info/NOXON/
                    I did it today for a NOXON Iradio 2 that was sitting from 2007 and it is back to life!
                      Hi All
                      Magnum, can you explain me how you flashed your radio firmware? I have an iRadio 300 but I can't find anything useful at the link you posted...
                        [SOLUTION 2023 and forever ]
                        Hi All, I have found way, how to use our dead Noxon iradio. It is not perfect, but it is better than having this radio like a furniture. I have iRadio 300. Here is how I am using it:
                        1. On pc, which is in the same local network as iradio, install X-DLNA, it is freeware.
                        2. Make sure your noxon is connected. If you are on wifi, you have to click "internetradio", it connects to wifi, but shows network error, but it is OK.
                        3. In X-DLNA click on webglobe:
                        4. Navigate to direct stream link like this one: http://s2-webradio.rockantenne.de/rockantenne or try other. Some radios you can find here: https://github.com/schreibfaul1/ESP3...Webstreams.txt
                        5. It plays automatically on PC, but you can stop it.
                        6. Click "Cast via" button:
                        7. Click on play.
                        8. Now It plays from iradio. You can now close X-Dlna, it will play forever, until you do not turn off radio.
                        OPTIONAL:
                        I am using bookmarks, so I have saved radio stations I am listening:
                        KNOWN ISSUES:
                        After some moments, device disconnects like this:
                        Then you just Click "Rescan". Point your mouse there, It appears.
                        ENJOY
