I've got an LG 49UH610V that has some weird display problems. The LCD panel itself doesn't seem to be broken but It keeps alternating between a good image and a bad image around every 2 seconds. (so it seems fine for 2 seconds and then switches bad for 2 seconds and keeps alternating, see video attached)
At the top of the screen there is a pink horizontal line which isn't visible in the video, this line never goes away it's always there no matter if the screen is currently "good" or "bad".. when I disconnect the left side of the Panel from the T-con, it only shows a solid image of vertical black and white bars however when I disconnect the right side, it shows the same bars but every 2 seconds these bars start to shake and then go back to normal and keep alternating just like the main symptom.. Any ideas on what's happening?
Something else I should mention, the T-Con main IC gets quite hot (not sure if It's normal.)
Link to Video : https://files.fm/f/p7ggchcn9
Thanks in advance
Thanks in advance
