Hi guys, i have a thonet & vander model Grub speaker system. The problem is there was 3 components burned and blown.
1 transistor which is - WFF7N60
1 IC which is - CR6848T
2 resistors thats 1 is through hole resistor 0.68Ohms and 1 SMD resistor.
I managed to replaced all the components except for the smd resistor. The top is blown so ive no idea to find out the value. Ive managed to check the datasheet for the IC CR6848T and the one goes from the gate connects to a resistor with the value 47 Ohms. Is it safe to assume 47 ohms can be used as a replacement?
