Asus x202e won't POST
    So, here is the story.
    I've bought an used x202e on eBay *in perfect condition, not a scratch on it*.
    It came upgraded to Windows 10, but since I wanted to do a clean slate I've cleaned all the partitions and formatted the hard drive. I've also upgraded BIOS from 206 to 210.
    So far so good. Then, I've installed Ubuntu on it, but I thought that it would be a good idea to install Windows 10 again and run it as dual boot.
    Windows 10 rewrote the GRUB so I had to fix that one as well, but I've accidentally erased its boot partition and (of course) it wouldn't boot.
    So I decided to do it again but this time, to do it properly, I wanted to install Windows first and than Ubuntu later.
    Again, I've deleted all the partitions, formatted the HDD and started Windows 10 installation from a pen drive. It went well up to a point, but then it got stuck on "Wait a moment" (or something) screen, and after some time I did a hard reset. After the restart, the installation continued but got stuck again. I did a hard reset once again, but this time laptop wouldn't POST anymore.
    What I get right now is: power led is on, Wi-fi led flashes for a second, HDD starts spinning and then it all stops. The screen is black and I can't enter BIOS or anything.
    I've checked the HDD - works fine, attached an external monitor to see if I'll get something that way - nothing. Tried to boot without HDD - same thing. Tried to boot with a pen drive - no luck.
    The rest of the components are soldered on the motherboard so I can't check if it's memory, processor or BIOS.
    I think that without the memory it should still be able to enter BIOS so it could be either processor or BIOS. Processors almost never dies on the default settings so corrupt BIOS seems most likely (or so I wish to think since it can be replaced. The laptop run on battery the whole time so there is no chance that there was a power surge or something that could fry the components.
    I've tried unplugging the battery, holding power button for 60 seconds, clearing the CMOS, no results.
    I've run out of ideas what to do so any suggestion is welcome.
    One more thing. I've noticed that plugin the computer on AC results in the same behavior as pressing the power button - computer turns on, fails to boot and remains on. There is also no way to shut it down while it's on AC - I have to do a hard reset and the computer will restart and star everything all over again. Maybe there's a hint.
    Thank you in advance!
    Re: Asus x202e won't POST
    try to flash bios
      The only way I could do it is with the programmator (which I don't have) since I can't find a way to get anything on the screen/get into BIOS.
      I can buy a chip online (it's W25Q64) but I need to buy it from someone who can flash it for me.
        Contact the seller, it's obviosly that you get a vicious item !
          That's the other bad thing, since my friend from the US bought this for me in November and didn't bother to even open the box. I've picked it up from him when I was in the US recently, but any time for complaint is long gone. I'm stuck with what I have.
            You have 6 months to open a eBay dispute on Paypal !
              Even if the warranty in the add was only a month?
                Good news! I've managed to fix the laptop. It was a bios problem. Bought programmer on eBay for 7 euros, unsoldered the chip, programmed it, soldered it back on and all in tip top shape now .
                Just one more thing, I've only found a programmable bios for x202e ver. 2 motherboard (goes into x201e laptops), which should be identical but I can't get my Ethernet to work. If someone has a bios dump from x202e, I would like to try programing with that one. Cheers!
                  try this..
                    I didn't want to bother with removing the chip again so I've used FPT to do the flashing. Everything looks the same, so I'm not sure if all parts were flashed or just the firmware part. Can you tell me if this BIOS is modified in any way, since I don't see a secure boot option?
                      must be flashing the ic bios tahts the good solution
