hey guys , need k54LY bios dump
    board is a K54LY REV 2.1
    ITE IT8572E
    HM65 CHIPSET
    THK IN ADVANCE
    Re: hey guys , need k54LY bios dump
    backup your old and try both
    Im Back... sort of...
      thk borbe , but you gave me a 2in one bios , i got this as well , i need them splited , i will post here my both bios , EC and Main .
      i think that fmor my files will be easy to split the new bios in the 2 files needed.
      here are my files
      im gonna upload the EC only from my board , i guess its enough to someone can modify and split me the new bios in both files EC and MAIN
      thk in advance
        techman bios master ? can you help me out here ?
          Hi
          First and always i need your original bios even if it bad ...asus don't have full dumps and you just can't use somebody else because it will have ME Region problem also is this a two bios board EC & Bio ? meaning not to getter? if it just one bios chip then its just one file they are togetter upload for me to help you.
          Robert
            i there techman , this is a 2 bios board , EC and main , on the 2 files i sent in attachment , i sent the the bios frmo the ASUS site , 1.36 mb ip file , and i also added my EC dump the 24.1kb zip file .
              if you need my MAIN dump as well , let me know i upload it for you
                Hi Yes i need the original main ..let me see if asus even has the EC.rom i didn't see it thats we could use from a donor board not the original file.upload because i'm almost ready to run out and won't be back until later today.
                Robert
                  here it is both bios Robert thk for help
                    i noticed that the bios frmo asus is bigger than the ugual 4096kb , so seems having ec merged on it , but im not sure , i dont have your knowdledge , i wish that heheh
                      that "ec" dump is Asmedia 104x USB 3.0 firmware as it seams to me
                        Hi
                        Your file is a mess for sure it won't work you need to wait until tonight i need to rebuild you a new clean ME Region ...that means all new clean never booted in another machine ....If somebody give you a dump from another machine it will have fans racing ,redome shut down and so on thats a dirty me region once a computer boots it married to that bin to that laptop and this is the case only on intel boards ...no amd no me region on amd.
                        If i give you a file it will work for sure leave the original EC bin on the computer dont touch that that an't you problem only main bios 4MB in size
                        Techman1025 talk soon
                          ala borbe , well then well cheked my friend , it was right by side of that asmedia QFN , and o noticed this was a bios IC , but wouldn't imagine it was asmedia firmware , very big error !!!!!!
                          so i guess the ASUS only have one bios !!!
                          , got it robert ? you got the main bios on that packet , so just chek it out and send me a good one with regions fixed etc . meanwhile will try with the one ala borbe gave me !
                          thk ALA_borbe !
                            @highpulse
                            you dumps are messed up.. mostly zeroes
                            @all
                            my file in second post K54LYF1-207.zip is a dump from working laptop
                            my file K54LYF1-208.zip has inserted new main bios from asus web... both should work
                            maybe problem is elsewhere
                            edit
                            found some asmedia fw for another board, reported to work fine
                              robert , thk ill wait ,
                              ala , thats not good
                              alltough the problem is that we work for outher stores and somethimes we grab machines that were "tryed to repair" by outher non professional people and we found some abnormalities like this !!!
                                found some dump reported to be working
                                you can try
                                  originally i wanted that bios just to rull out problem on the ITE due to not having correct 5 volts line , i got perfect 3.3 line , but the 5 volts line its only 0.91 volts , replaced the min regulator to see if it would change , but still same value . usually ITE controls the 3.3 and 5 volts line , so that why i wanted firstly this bios to carry out ITE problems , but even with your dump ALA , still not getting 5 volts line , only 0.97 volts !!! so problem is around ITE for sure , cheking main regulator is ok , all fets are ok as well , there are no short on both lines , both have good Kohm values .
                                  so if someone have this schematic i will apreciate !!
                                    schematic and board view anyone ???
                                      Hi
                                      Here is the new file i made for you .....if this don't work you have other problem ..to know if bios is working rsmrst 3.3V S5 3.3V do you have it caps light up on keyboard if pressed or usb mouse lighting up if yes to all bios is work enjoy.
                                      Techman1025
                                        Hi
                                        The original bios you uploaded was a mess noways it could have work ....so you just might have more then one problem do what i send start from point A and we will go from there.
                                        Techman1025
