broken R035 resistor in a PS4 PSU
    its a PSU for PS4 Slim
    spec for this resistor is: 0.035 Ohms, 3W, 1%, size 1225
    this resistor is broken and burnt. i cant find this resistor to buy locally. can i a small fuse as a replacement?
    Re: broken R035 resistor in a PSU
    It sounds like a current sense resistor at that size, so no you can't swap with a fuse.
      This might help Mouser has this listed but Non-stocked LRF3W-01-R035-FT
        thanks. only place i found this resistor are on ebay from china.
          before you burn the new one, it sounds like something got shorted out to make it blow!
            the fuse was dead also. no continuity at all. i cant find anything else broken under microscope. no schematic for this psu and i dont have another know good psu. worth a shot replacing it and see if go on fire again. if cant fix then i just throw in the bin. thanks
              I think it's todo late but nerd to check q6 , ir shorted You nerd to change it
