[emission only] vacuum tube tester safety
    Well, I was able to acquire a vacuum tube tester. It's a cheap crappy emission only (i.e., no transconductance/mutual resistance) tester - but I realized it was even crappier than I thought. The power supply is an autotransformer, and the "floating wire" top cap lead has an electrical path to line power! Touch the cap wire, get electrocuted!
    I would suspect all those old console tube testers were isolated especially if it had one of those flying top cap leads... or at least I hope it would. This one is indeed cheap cheap cheap, alas it does get the job done...
    Re: [emission only] vacuum tube tester safety
    well i suspect it's normal, back in tube days tv's & radio's where often live.
      They did have live chassis like the AA5 but you can't touch any part of the live portion with your finger... but in this case if the tube cap wire touches something, it could be quite problematic...
        that's not completely true, you could touch the antenna connector etc at the rear - and with a 2pin plug you have a 50/50 chance of winning!!
          I thought AA5's had internal loop antennas, if not, they are capacitive coupled with a really small capacitor (so that any leakage would be less than ~1mA to GND at 60Hz)?
            go watch some "carlson's lab" vids - it will put you off old stuff forever!!
            he had a chrome plated radio the other day, plug it in the wrong way and the whole shell can go live - and it did!!!
              If things like this were fine back then and modern CCC/poor design is not, what has gotten into us???
              Hooray...found some broken vacuum tubes, at least my stockpile of vacuum tubes is going down, no sense in keeping the bad tubes...
                it's down to education.
                in the past people simply knew that you dont touch metal bits when something is on!
                also, people used to do risky shit a lot more.
                fixing a fuse with the foil from a pack of smokes was so common that it was more likely than a working fuse!!!
                2way adapter?? no, just poke the wires into the wall and smash the plug into the socket over them - saw that a lot.
                and my fav'
                making an extended cable by twisting the wires and wrapping it in tape.
                  I wonder if I could hack this tube tester to do transconductance tests by feeding some signal into the grid... :o
                    well you can find schematics for most B&K gear - so your only limited by time & patience.
                      The ones I remember all had a power trans. I remember the days when some of the gorcery stores had a tube tester . Found these links for you .
                      https://fairradio.com/?s=+tube+tester+
                      https://www.ebay.com/sch/i.html?_fro...ester&_sacat=0
                        Surely any electronics lab (apart from where you are working solely on low voltage devices) should have an mains isolation transformer powering the test bench. They are not even expensive
                        Follow me on YouTube
                        Learn Electronics Repair
                          this set must have been missing its isolation hardware.
                          not unusual for these parts to have degraded in the last 70+ years and replaced with metal parts by someone who did not understand why the chassis mounts were made of "cheap" plastic or rubber.
                          or used a metal knob in place of a plastic one.
                          aa5 sets require a bit of caution when testing/repairing them.
