Hi
I have a Toshiba 43L3753DB.
When turned on, the Toshiba Logo is distorted and unreadable, but once the TV is booted, pressing the "Menu" button gives a visible menu, but if you try to select any menu, the screen becomes unreadable. The No signal message is readable and so is the info bar at the bottom of the screen, it just seems that as soon as there is a requirement to provide an image across the entire screen, it becomes unusable.
When the screen is unreadable, the PSU noise increases.
The 12V is good (12.14V) and is present on the T-Con fuse.
On the 17IPS62 PSU, Diodes D23/24/25 have about 37.8V, but this reduces when the fault is present. Diodes D7/8/9 have 12.14V on the cathode. I have not performed a diode test on any of them as yet.
The LED back light voltage is 85V. but the back lighting does vary in brightness during boot up.
Does this sound like a PSU, Main board or Firmware issue?
Mainboard is 17MB110P.
I have PSU and Main board from A Toshiba 32L3753DB. The PSU has a smaller transistor in the HOT section, so probably cannot be used even as a test. The Main board is set up for a 32" screen, so can this be set to work for a 43" screen by flashing the firmware?
Any help and advice gratefully received.
Regards
Russell
Regards
Russell
