its not compatible brother because batt connector voltage over 5v up which is not the normal btw thanks..
if it is an Aspire AIO ZC-606 the bios is compatible because it is made from the Original posted by you, the update on the site, after which the ME region was cleaned ... I don't realize what you measured and how (with the battery in the socket? , with it removed?), (with the desktop on ?, with it off?), where did you measure ??? ... give you more details ... any measurements you made has nothing to do with the bios..check the voltage measuring instrument battery.
ok brother thanks ill try your bios again ..the measurement ive done was in cmos bateri and its measure was 5vup which is not normal..maybe other parts were damage no voltage comes out also in 19v dcin..i tried in dc bench current draw was 0.053 injecting direct to main port..thanks brother
