To test I plug in a 12v source and try by plugging a multimeter on the output and turning on the blue trim potentiometer it's fix at 12v however I turn it up or down what could be wrong ?
brand new buck converter does not step up or down
Re: brand new buck converter does not step up or down
Are you sure that you are turning the pot control for the voltage because one is voltage and the or one is current9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Originally posted by sam_sam_sam View PostAre you sure that you are turning the pot control for the voltage because one is voltage and the or one is current
Probably for best results because this is a buck converter not a boost converter which as adjustable the voltage control your voltage would go beyond the input voltage but on a buck converter it is the opposite in that you have to have some load on it for the voltage control to work but the current control also affects the voltage outputLast edited by sam_sam_sam; 08-30-2022, 07:54 PM.9 PC LCD Monitor
1 Dell Mother Board
Originally posted by R_J View PostYou don't have a load, so it likely just charged the output cap to the highest voltage.
What happens when you put a load on the output dose it charge at all9 PC LCD Monitor
1 Dell Mother Board
Originally posted by stj View Postno, because the output cap holds a charge, and the charge is going into the chips feedback pin.
unless your output cap(s) have a discharge resistor you never power up without a load
