Hi everybody. i also need bios dump for 5591. If you have that file please send it to me. Thank you very much
need bios dump for Latitude 5591
Re: need bios dump for Latitude 5591
Originally posted by sunbabu369 View Postpost your old dump
this is bios dump
Absolute is enable. is there any way to turn it off?
thanks
Re: BIOS Unlock Dell 5591 LA-F711P
Originally posted by Markus1741 View PostHello, maybe someone can help me.
I have a Dell 5591 with a BIOS password can someone unlock this please.
The motherboard is an LA-F711P
good luckAttached Files
Originally posted by black0hackers View Posttry and let me know
good luck
Solved the problem.
Thank you very much.
https://beta.bios-pw.org/
62Jy4Ra2NGzyQ[xMLast edited by Markus1741; 03-16-2022, 09:27 AM.
Originally posted by Markus1741 View PostSorry at first it didn't work. Fan spins at full speed. Then press Alt + F Press F2 still window with unlock
Solved the problem.
62Jy4Ra2NGzyQ[xM
Originally posted by Salmus666 View PostHello
Can somebody clear ME ?
I cant figure it out.Attached Files
Originally posted by Salmus666 View PostThank You.
It works.
What did you do?
Salmus666
I had to choose the right CSME version, I only got it on the fourth attempt.
There are several CSME versions, it is important that no errors are displayed with MEAnalyzer.
https://winraid.level1techs.com/t/in...ols-2-15/30719
Dell Latitude 5591 - Disable ME via HAP bit only
BIOS package from Dell: https://dl.dell.com/FOLDER10054153M/...530_1.27.1.exe
I have experience with using flashrom and SOIC clip, but I couldn't find the BIOS chip on this motherboard. There was one 8-pin chip that was 1 MB in size but it wasn't a valid image according to me_cleaner, although I almost wonder if flashrom needed updated or something. Does anyone know specifically where the BIOS chips is on the 5591?
Is it possible to flash only what is needed to set the HAP bit for ME without needing a hardware flasher? In the past I did --soft-disable-only with me_cleaner.
I'm not sure if I have Boot Guard. I believe I disabled Boot Guard via setup_var variable or something because it caused a BIOS update to repeatedly fail a flashing step, but I'm not sure if it was BG or something else.
Re: Dell Latitude 5591 - Disable ME via HAP bit only
Originally posted by Espionage724 View PostBIOS package from Dell: https://dl.dell.com/FOLDER10054153M/...530_1.27.1.exe
I managed to get my SOIC clip onto the BIOS chip, dumped it, me_clean'd the BIOS, and flashed it back. I did soft-disable-only and descriptor flags, but it doesn't seem like the descriptor flag on ME allows writing. There's no HECI PCI device, and ME is reported disabled from FPT and MEInfo CSME tools.
The BIOS chip (at least mine) was near the PCH chip, and I had to remove the plastic covering holding the wifi wires, battery, and covering the touchpad to reach it comfortably.Last edited by Espionage724; 06-27-2023, 03:39 AM.
