brand new buck converter does not step up or down
    To test I plug in a 12v source and try by plugging a multimeter on the output and turning on the blue trim potentiometer it's fix at 12v however I turn it up or down what could be wrong ?
    Re: brand new buck converter does not step up or down
    Are you sure that you are turning the pot control for the voltage because one is voltage and the or one is current
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      You don't have a load, so it likely just charged the output cap to the highest voltage.
        to be sure I tried both but I know that the left trim is for volts if viewed from above
          do you need load to test? if so can you explain further please
            Probably for best results because this is a buck converter not a boost converter which as adjustable the voltage control your voltage would go beyond the input voltage but on a buck converter it is the opposite in that you have to have some load on it for the voltage control to work but the current control also affects the voltage output
            9 PC LCD Monitor
            1 Dell Mother Board
              please look at this from minit 12 https://www.youtube.com/watch?v=9--_jaxiXhE&t=16s
                What happens when you put a load on the output dose it charge at all
                9 PC LCD Monitor
                1 Dell Mother Board
                  have not tried yet, but I will do and get back to you. normally you should be able to test even without load
                    no, because the output cap holds a charge, and the charge is going into the chips feedback pin.
                    unless your output cap(s) have a discharge resistor you never power up without a load
                      Clear and concise explanation thank you
