First I replaced the backlights. Then I found three bulging capacitors, one leaking, on the power supply board. Now, when I turn on the tv, the picture flashes with an image and then the picture goes away. I can unplug the tv and plug it back in, turn it on and the same thing happens. Please help. Thanks!
JVC lt-42em73 Flashing Backlights
Re: JVC lt-42em73 Flashing Backlights
I checked the solder at the backlight plugs and they are fine. I disassembled the tv again and checked the backlights again. Removed everything down to the backlights, plugged in the tv and the backlights will flash once and go out. I tried another set of good backlights and they wouldn't even come on at all. So at this point I believe the problem is the power supply board. As I mentioned earlier, I replaced some bulging caps but apparently there's something else wrong with it. Sorry for the delay in responding but I haven't had the time to mess with the tv. Any ideas? Thanks in advance!
Originally posted by nomoresonys View Postget out the hairdryer and heat all those caps, then see if the tv stays on longer, if it does you can narrow down the culprit with more selective heating.
