This is the new EBC-X 8-Channels 18650 lithium Battery Capacity Tester that I bought
    I had the battery testing machine for about month or so and finally found a home for all of it to be together in one place
    The battery testing machine is on the top the thing is the self for the batteries testing
    The computer is on the very bottom of the cart with a power strip in the back/side of the cart
    I also have another battery testing machine that is very big as well and I going to buy another cart for this one as well but I have to make a face plate for that one because it is not like this one where it is setup to be put on a cart
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: This is the new EBC-X 8-Channels 18650 lithium Battery Capacity Tester that I bou
    very nice quite large but assembled, is it 8 chanel control?
      Yes it is eight channel battery tester and I have had up to 5 of them at one time already before I put on the cart
      I bought some battery holder for the battery testing machine here is the link to ones that I just bought and waiting for them to get here
      https://www.ebay.com/itm/155075483177?var=455251086920
      9 PC LCD Monitor
      1 Dell Mother Board
        I just bought a 20U equipment cart the tallest one that is available from the same manufacturer I have plenty of room for the computer the eight channel battery testing machine and two other battery testing machine that are one channel each and room for the batteries under test
        9 PC LCD Monitor
        1 Dell Mother Board
          Geeze Sam… how many batter packs do you have? Nice setup… have to admit.
            A lot of them but once retire I will not have the money that I have now but I will have time to devote to all of the projects that I have in mind but the Milwaukee battery packs became a priority because of my son getting a semi truck and needing to be able to use my Milwaukee battery powered tools and finding out that I was having issues with the high amp hour battery packs
            9 PC LCD Monitor
            1 Dell Mother Board
              I suppose I have a variety of chargers too. Last lightning strike, it took out an older Pulsetech brick charger. Put replaced a $5 TOP247YN and saved $250 for a new one.
                I finally got in the battery holder that I ordered now I have to get a plastic cutting board to mount these battery holder so I can use them
                9 PC LCD Monitor
                1 Dell Mother Board
