I was fortunate enough to be given board and schematic files for these two boards yesterday. They have been tweaked by another member and he also worked out what the actual board numbers they were. They were only labelled as High and low configurations of A2442. As far as we can tell the 820-02098 is the M1 Pro and the 820-02443 is the MI Max. Another friend also helped by removing his board to aid in identifying which board came from which machine. Thanks guys we got it sorted and now shared.
820-02098 and 820-02443 brd and sch files
My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SATags: None
Re: 820-02098 and 820-02443 brd and sch files
Possible to share the original ".brd" files?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostPossible to share the original ".brd" files?My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
Thanks.
Semantics on the points outline is different from previous BVR3 boardviews.
Previously last point closed the outline, in these files it ends on an whitespace.
Fixed it so that it is the same as previous files.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Hey, Piernov, any chances of you emailing me the .brd? I have a damaged macbook pro a2442, and the tech guy I found to repair it says the brd would help him a lot.
Also, thanks Pedro147 and Piernov for helping the comunity with this! I had lost my hopes of having my macbook back, you guys restored it!!
OpenBoardView supports BVR3 files.
Here are the original BRD files anyway.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by Pedro147 View PostI was fortunate enough to be given board and schematic files for these two boards yesterday. They have been tweaked by another member and he also worked out what the actual board numbers they were. They were only labelled as High and low configurations of A2442. As far as we can tell the 820-02098 is the M1 Pro and the 820-02443 is the MI Max. Another friend also helped by removing his board to aid in identifying which board came from which machine. Thanks guys we got it sorted and now shared.
Thanks!
Originally posted by dmobilept View PostHi guys! I can't open this files with Boardviewer. What do you use?
Thanks!Last edited by piernov; 12-01-2022, 04:48 PM.My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
Originally posted by HooF View PostI see board view but no schematicMy YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
Originally posted by theupel2 View PostAny luck with the .PDF?My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
