MBA A1932 820-01521-A no Post after few seconds it restarts
    Hi, I need help fixing this. Any help will be highly appreciated.
    Got a macbook air A1932 820-01521-A with the trackpad click not working, the fuse was blown (its never the fuse) I tested the line and seems ok, replaced the fuse and it worked again... all good BUT when I tried to remove the board again I pressed the reset switch (SW6955) next to the battery connector WITH the USB-C power still connected to the board.... I pressed and kept pressed for some seconds twice because the fan started to spin... then I realized why.... 😕
    After that the machine wont boot, It gets 20V and start booting it goes briefly until 0.57A the returns to 0.45-0.49A and stays there, after some seconds it restarts the boot process again (watch the video), I dont get anything on the screen. the CPU start to get hot and fan starts spining, I guess it reboots because CPU gets too hot.
    The switch SW6955 still gets 3.3V
    All the SLPS2R are with the correct voltage.
    PVDDCPUAWAKE_SW0 to _SW3 when booting 0.97V then goes to 0.55V and stays there.
    PP1v2_S0SW: 1.19V
    PP1v_S0SW: 1V
    PPVCCIO_S0_CPU: 0.95V
    PPVCCSA_S0_CPU: 1.1V
    PPVCORE_S0_CPU: 0.84V
    PPVCCGT_S0_CPU: 0V
    ALL_SYSPWRGD: 1.8V
    L7210: 0.844V
    L7230: 0.844V
    L7230: 6.5 Ohms
    L7210: 6.5 Ohms
    L7430: 5 Ohms
    L7410: 5 Ohms
    L8102: 52.4 Ohms
    L7030 is 1.9Mohm
    Trackpad click still works, no green light on shift key, if I connect an usb to the usbc it gets light but not like it is reading it.
    Watch the video
    Re: MBA A1932 820-01521-A no Post after few seconds it restarts
    *imnub* is the keyboard ok? is the close panel switch engage?
      Originally posted by helpmerepair View Post
      *imnub* is the keyboard ok? Is the close panel switch engage?
      Keyboard works, i can get into DFU (tried to restore but didnt work)
      What do you mean by „close panel switch“?
        if lid not fully closed+bad kb =/
          explenation : a clietn wit non working kb return me a fully working battery and macbook to me , i told him that if he wanted to boot the laptop he had to plug in the charger n thats it , then next day he says hey its not working my mb is dead ... he bring it i flip the mb unplug the battery and tell myself its a SMC fault.,..
          but nah , it was faulty close lid switch
            happends only wit dead kb + bad lid sensor lol
              sudo nvram autoboot=%03
              thats auto power on wit charger or lid up
              sudo nvram autoboot=%00
              thats only power button
              in terminal while into a session for sure hehe
                The logicboard behaves the same when I take it out with nothing but the usb-c connector. The booting amperage changes are the same and the cpu gets hot.
                  bad battery +charger might be ur answer lol
                    if a macbook pro a1398 dont have a good battery it goes into boot loop
                      Tested with new battery and different working chargers…
                        smc chip chek wit thermal cam for faulty chip
                          if u dont have drop some alchool n watch for fast drying area
                            if none micro circuit get hot except cpu , chek for screen defect if not ... core n ram defect ? thats what i know so far and i rmbr ya that im nub lol
                              Macbooks with T2 chip doesnt have SMC
                                i bought a flir c3 at a pawnshop 2 week ago and its alrdy not powering up XD plz god help me
                                  58-95
                                  https://imgur.com/a/NVC9Kde
                                  https://imgur.com/a/bmrIjk7
                                  38-95
                                    On the A1932, post the voltage readings of:
                                    SMBUS_3V3_BATT_SCL
                                    SMBUS_3V3_BATT_SDA
                                      would love to , dont have acess to machine =( ( btw hows is the lion head ? hehe )
