I need to replace this small diode that is found on the logic board of a hard drive. What type of diode is this so I know I buy the correct one.
hard drive logic board Diode identification
Re: hard drive logic board Diode identification
The hdd should turn on without that TVS / zener diode installed, but you loose over voltage protection. The new PSUs where you can disconnect unused cables aren’t standardized. So a Thermaltake cable.will fit in an EVGA PSU, but it reverses the voltages on the sata end. And then exact this will happen when you turn the computer on the first time. Guess how I found out.
I’ve replaced the diode and kept the HDD running. Got over 8000 hrs on it, no problem.Last edited by CapLeaker; 09-30-2022, 03:51 AM.
Originally posted by CapLeaker View PostThe new PSUs where you can disconnect unused cables aren't standardized. So a Thermaltake cable.will fit in an EVGA PSU, but it reverses the voltages on the sata end.
I wonder how many versions of the cable here, surely hope it's not all 180-odd combinations...
Originally posted by eccerr0r View PostI was recently looking at my Antec NeoHE "modular" and a random SATA power cable that seemingly uses the same connector. As skeptical as I usually am I tried tracing the wires on the cable, and lo and behold: the wires don't go in the same order. Might have saved a zener diode's life here...
https://www.badcaps.net/forum/showthread.php?t=58320Last edited by CapLeaker; 09-30-2022, 11:41 AM.
I ended getting a 12v to 5v dc-dc converter. It didn't work, output was shorted. Turns out there was a zener crowbar that was fried and melted the plastic case.
Oddly enough it isn't obviously clear which connector is input and output for the dc-dc converter, so guess what happened...
