Hi, I've got a Samsung UN55KU6300FXZA that doesn't turn on but does show a blinking red (standby) light. When I press the power button the remote the red light blinks rapidly but faintly, pretty much the entire time I hold down the button.
Before I pay for a new power supply board I am hoping someone else can confirm my determination. Or maybe provide me other things to check before pulling the trigger on a replacement.
I haven't found schematics for the board that I have but I've read up what I can on diagnosing and repairing and have the following information:
Configuration:
Model Number:UN55KU6300FXZA
Version: CJ05
Power Supply board: BN44-00807A
Processor board: BN94-10838D
I have the following tests / results. All measurements are DC volts. I added a #2 and a #3 on top of the board pic to show where I made the measurements (with respect to the chassis ground.)
1. Disconnect power supply board and Turn on TV: No backlight
2. Measure CNL802 (backlight connector) pin 1 indicator: 180V with processor board connected, 88 to 95V with processor board disconnected. If I unplug the backlight connector its about the same - 88 to 100V. If I understand the silkscreen note it seems like this should be either 277 (2D) or 337(3D).
3. Test point at DM853C and DM854C Cathode: 12.8 with periodic drop to ~3V, probably once a second. Also seems to be accompanied by very faint 'pop' or 'tick.' Silkscreen on board says Standby 8V / On 13V. It's definitely not either of those steady state. If I disconnect the processor board, it varies from 9V to 13V.
Anyone have any thoughts they are willing to share? Or additional recommended tests to clarify the problem?
Again, I'm trying to decide if this is enough information to determine that the power supply board is faulty and that replacing it will fix the problem. I can also post pictures of the system layout and harnesses.
Thanks in advance.
Configuration:
Version: CJ05
Thanks in advance.
