I need help on this LENOVO IDEAPAD 320 DG425/DG525/DG725 NM-B321 Rev:1.0.The problem is turns on lights on the power button is present cpu is not spinning and no display, already tried reflashed with good bios and ec here in this forum but still same issue. i have attached the phone on the measurement of shorted coil and cap resistance coil is PL2202 and PL1401 and the cap is PC2251 I Dont have a schematic for this . anyone could help me solve this problem please
LENOVO 320 turns on lights present cpu not spinning
Re: LENOVO 320 turns on lights present cpu not spinning
If the cap was shorted, coil will also shorted to gnd.Since you measured 0.04K resistance, so cap was simply not shorted. It may have shorted now 'coz you applied heat to remove it. These sort of caps has a tendency to go short when heated-so you should replace it. You are simply getting lost in trobleshooting it. When laptop is turned on, try to measure voltage on all coils and see which rail(s) is not rising and focus on that part.
Try this:
https://www.badcaps.net/forum/showth...80#post1217080Last edited by Vesko356; 05-01-2023, 09:13 AM. Reason: Attached schematic removed and replaced with link.
