Samsung UE48JU6445K Vertical Lines
  • tezeteta
    • Sep 2020
    • 9
    • Ireland
    Hi Folks,
    My Samsung TV has some vertical lines on the image (attached). If I don't have any input connected to the TV, I can see just 2 lines (read and yellow - the 2 lines shown on the left side of the scroud image)
    Another symptom is that the COF tab is super, super hot to the point of burning skin.
    Do you guys think that this is a screen issue? or can be a tab or something that can be reparable?
    Thanks in advance,
    Tezeteta
  • R_J
    • 9532
    Re: Samsung UE48JU6445K Vertical Lines
    It is the cof that is defective, Not repairable without special equipment to change the cof tab.
    • tezeteta
      • Sep 2020
      • 9
      • Ireland
      Thanks RJ.
      Is there any way to make 100% sure that this is a COF the issue?
      I pressed the COF on the 2 ends and the image didn't change.
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • Ancient1
        Strange LG TV issue : Image vertical lines in black screen
        by Ancient1
        Hi
        Asking for a friend.
        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
        but here its the opposite !
        TV has new T-con = same issue
        A missing panel voltage would have global effect
        So , what should one do ? how can I find where the fault is ?
        Thanks !...
        02-05-2025, 03:37 PM
      • polaro
        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
        by polaro
        Greetings,
        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
        08-27-2022, 08:46 AM
        09-07-2024, 05:50 AM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
