Vizio TV E470VL SMPS Flucuation Output Voltage
    Re: Vizio TV E470VL SMPS Flucuation Output Voltage
    In the attached picture these two MOSFETS, voltages seems weird, is it normal that when I measure in DC VOLTS at the drain, voltage starts out as high as 27 volts and lowers down to 9 volts?
      Are you using the neg. side of bridge rectifier or neg. leg of main filter cap for ground? either is ok when checking voltages in the hot side, use caution HIGH voltage on hot side.
        Negative side of big cap
          Not sure what we've covered, you do have around 160v on the big caps when in standby? powered up it should go up to around 390v.
            Do you have a steady standby voltage or is it still 0?
              Did you test the new zener diode before replacement?
                not sure, maybe test Q101 and 131, and test every resistor in that area, the values should all be marked see the tiny writing, make sure the ohms reading is close to the value marked on the resistor.
                  Yes
                    167 volts on the filter caps
                      No standby voltage, no output voltage of any kind
                        Any ideas why there is changing voltages on these mosfets? The mosfets just above them are steady and stable at 167 volts
                          How do test Q101 and 131 in circuit with a multimeter?
                            yeah, i guess, see if its short, i believe you test drain to gate and drain to source, might be middle leg to each outer leg if continued beep or close to 000 in diode mode its probably shorted. Dont get it confused with both outer legs because they can show continuity and be ok. Prolly best practice is get the datasheet of the component to be sure of the pinouts.
                              There is only 1 volt at Q707 at the drain. Picture attached. For orientation it is right next to big filter cap, cap farthest away from input power. Any suggestions?
                                make sure resistor R704 is ok, it looks beat up from the picture.
                                  I wanted to thank everyone for their help in trying to fix this power supply. I was not available to fix it an ended up buying replacement at BuyQual.com at a reasonable price.
                                  thank you and God's Blessings,
                                  Danny
                                    well we gave it our best shot, thanks for update, it would probably be a lot easier to determine what's wrong with it now that you have a working board to compare with, thanks for the blessing, right back at ya.
