Good evening please I have an elitebook 6470p machine which in bios the keyboard and the mouse works well but in Windows nothing of the two works
Help me pleace
Re: Help me pleace
Did you try another copy of windows !
Post your old dump here : https://www.badcaps.net/forum/forumdisplay.php?f=40
Don't forget to save a copy
Re: Help me pleace
what kind of os are you trying to install...what version of windows.. do you happen to install the chipset driver first.. use an external usb mouse or external keyboard and then install the chipset driver..if that doesnt work.. try to install a lower version of windowsNever stop LEARNING because life never stops TEACHING!
Re: Help me pleace
when did this happen after installing a new windows os or it just suddenly happen..if nothing works try to reflash the bios to a higher version maybe its corrupted in someways.. did you check the bios battery? sometimes it makes weird symptoms when the voltage is too low..Never stop LEARNING because life never stops TEACHING!
