HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by RethoricalCheese View Post
    This method is not okay... You should warn people that MPM will be unlocked and all DMI must be reinserted again.
    Try this instead - you just need to reset security settings to default after you get into bios.
    where is offset to fix sir?
      Hi everyone, quick question: I'd like to avoid to desolder chip, since laptop si still under warranty for 6 months. For that, I'd like to dump EPROM with a clip (may not work, of course, since chip is still soldered).
      First, did you have success with an in-circuit reading? Second, do you know where I can purchase a clip, but not an SO type, but a QFN type? (QFN-8)?
      Thanks !
        There is none to tell. Point me to your file, I'll do it manually for now.
          Here is it Sir. Original Main and Ec bios file add below
          i has do it by myself: replace EC bios file (non pass) from another laptop, password is remove, but there are is problem when it turn on even when i clear ME Region Main bios.
          display showing
          "HP Endpoint Security Controller Problem
          There is a problem with the HP Endpoint Security Controller on the unit
          Please contact HP Inc. to have the unit serviced "
          Can you fix it to use for another Laptop bios password
          thanks you!
            Hi to all, this works for HP Sure Start Password? Thanks
              display showing
              thanks you!
              First you would want to flash back both original files, just to see if that error disappears.
              let me know if it disappears, then I will try to patch correctly.
                it disappears sir. only aks for password
                  Try this and let me know if it works or has any issues. Flash only EC bios.
                  You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.
                    it working, password is gone. now i test it on another laptop and let you know how it going! many thank you to Sir!
                      Nice. Do not use the same file on another laptop, you will brick it. Make copies of both chips, just in case and just send the EC file here. It's a bit tricky to get it correct.
                        Hello friend I need your help please, I have this equipment with password
                        HP Elitebook 840R G4 I tried to clean the file with the tool that you published on the 32mb chip, but it did not work apparently the password is on the 16mb chip you. could you check it please.
                          if it works enter the DMI information ... proceed as in the video ..
                          https://www.youtube.com/watch?v=9T57ktw8n3Y
                            Hello Plague Friend, I recorded both files that you gave me but there is no image, I have reloaded the original files and I have an image .... I appreciate your help, this model seems to be different in the forum there is nothing about this version (840R G4) Helpme please..
                              Nah, this still needs main bios mod only. This should work fine and without needing any messing around with DMI.
                                Excellent friend RethoricalCheese, it worked perfect, but tell me I did it with your v1 tool, and it didn't work, did you do it manually? or I did something wrong thank you very much master.
                                  I did it with my new and improved tool which I have not published yet (because automatic unlocks on newer models is a bit more tricky than it seems. Still needs more improving and testing).
                                  Old tool had a few bugs with certain bios dumps and your bios dump was an example of that.
                                    46 / 5000
                                    Resultados de traducción
                                    Ok, I'll keep an eye on the new version, thanks.
                                      Please unlock hp 430-g1
                                        Can you make patch (unlock) password for my HP 840 G5.
                                        This is EC file...
                                          This is EC file...
                                          Be sure to reset security settings to factory default.
