HP BIOS unlock tool
    Re: HP BIOS unlock tool
    please can someone help me unlock my hp 830 g7 bios password
      Try
      Become a Badcaps supporter
      Thanks to all supporters.​
        Originally posted by RethoricalCheese View Post
        I did it with my new and improved tool which I have not published yet (because automatic unlocks on newer models is a bit more tricky than it seems. Still needs more improving and testing).
        Old tool had a few bugs with certain bios dumps and your bios dump was an example of that.
        sir please help me unlock my hp 830 g7 bios password.
        Last edited by SMDFlea; 07-26-2021, 03:11 AM. Reason: Bios removed, Double Post !!
          Did you read post #963 ,the reply to your post at #962 .Are these the same ones you`ve already posted at #962 ?
            yes same post but password still exist
              try this..
                Hi guys,
                i need some help finding the 2. BIOS Chip also the EC one on HP Elitebook 830 G6.
                The Big one with 32 MB i got already. On the other side of the board, there are 2 Chips:
                MX25L12873F (I think this is the correct one cause 128Mbit = 16MB)
                And the Winbond W25Q80DV (I don't think this one cause 8 Mbit = 1 MB)
                But i am not 100% sure. Could you please help? Which is the correct one?
                Thank you
                  mx25 is the 16mb bios chip 👍
                  Originally posted by onelook View Post
                  Hi guys,
                  Thank you
                    Yes MX25L12873F is main chip
                      Thank you for your answers.
                      Could someone please unlock for HP 830 G6
                      Thank you
                        Thank you
                        try..
                          Originally posted by peste View Post
                          try this..
                          thanks a lot for your help.its working perfectly.
                            remove password hp 830 g7 6050-3142001-mb-a01 thanks
                                I have 3 HP Elitebook 830 G7 with bios passwords and was looking for some help. Here is the 16mb dump of each. Thanks.
                                  Upload main 32MB dump too.
                                  The same applies for Mrnixdorf.
                                  There is no way to do the unlock with just 16MB file.
                                    Not correct It's just that it seems a little bit hit-n-miss for now. I've done a few here when I have been 100% certain it works on that machine.
                                    A small part of first padding on 16MB needs to be cleared.
                                    Just in case backup your 32MB and then try this.
                                      Surprise, surprise , that's new approach, nothing to do with the old method - very interesting, for which models is it applicable/tested?. BTW how far did it go with the HPU v.2?
                                        Many thanks
                                        Ok seen
                                        but information seem encrypted?
                                        a xor or others swap bytes can be use for see may be ?
                                        what information is written in this part?
                                        Just 16mb is enough now or always do both for bypass?
                                          Just continue doing it the old and tested way. My way is actually older but the problem is that I don't get any newer machines to test enough to get it working on all machines. Thatswhy I haven't published new version yet. It would just complicate things.
                                          On the ones I do get, I always only modify 16MB chip.
                                          HP doesn't use xor sadly. So decrypting wouldn't be viable.
