Dell Latitude 7480 Bios Password
    Can any help me remove the Admin Password. suffix is E7A8.
    I have attached the Bios dump. Appreciate your help.
    thanks in advance.
    Re: Dell Latitude 7480 Bios Password
    Here you are Dallas :
    Become a Badcaps supporter
    Thanks to all supporters.​
      Thanks a lot, it worked no more password required.
          Re: Dell Latitude 3400 bios password -E7A8
          Help bios password Dell Latitude 7480 , NZYMNH2-E7A8
            Upload your bios backup.
              Thanks, while I saw your post, I found a clean BIOS, sewn it up, everything is fine. Suddenly I spread it to someone useful
                It won't be usable for anyone but you, or at least ME Firmware should be cleaned, if it's sewn properly of course - I haven't inspected it.
                  I found it on the Internet, I asked for it, the laptop works. Here is my dump with password
                    Unusual as there`s no OEM public key hash,no boot guard,no key manifest.Did you flash the bios with all power removed,main battery and CMOS.
                      tomorrow the m2 disk will come to him I will install the system then I will write off exactly about the performance
                        I found a clean BIOS, sewn it up - "прошил"
                        Now I understand what you meant by "sewn it up" - just the process of programming the chip, I thought you put together "by sewing" a new edited bios based on yours, but you didn't really change anything at all, you've just found somewhere some bios and you've simply programmed it into your laptop. I wouldn't say it's a good idea, not at all indeed but you know best.
                        everything is fine.
                          can you fix mine if it doesn't work?
                            Yes, of course.
                            If you want just say so.
                              Yes, of course.
                              If it's not hard to redo mine. Windows installed, everything works except USB Type C and LAN network card. The history of the laptop is unknown, but it's interesting to try, maybe the problem is in the BIOS
                                I told you!
                                Let me guess: Code 10 in Device manager.
                                P.S. Give me some time to prepare the file.
                                P.S.2 Here you are (same version as yours 1.19.0 try & leave feedback):
                                  Thanks on Monday I will change your version and unsubscribe
                                    [RU] отпишусь = [ENG] I will respond / I will answer
                                    [ENG] unsubscribe = [RU] отказаться от подписки / прекратить подписку
                                    A small error in the bios leads to Code 10.
                                    A small (Google) translation error leads to a change in the meaning of the sentence.
                                      I told you!
                                      Great job, everything loads without passwords and errors, you are a wizard
                                        Hello.
                                        Thank You!
