I have an asus x453ma boots fine but the problem is the charging on the battery battery light indicator orange is present, in the windows it says plugged in charging but the battery shows 0% not going up.And also i cannot turn on with battery only when i pressed power button blinks then stops.but when i plugged charger only and battery plugged in it boots fine and no problem.Anyone can help on this please
Asus x453m charging problem
Re: Asus x453m charging problem
Originally posted by String2016 View Postthank you for the response imranromi already tried changing new battery but still the same issue.I dont have schematics for this but i try to check mosfet around the battery connector and gave feedback soonAttached Files
Originally posted by String2016 View PostI have an asus x453ma boots fine but the problem is the charging on the battery battery light indicator orange is present, in the windows it says plugged in charging but the battery shows 0% not going up.And also i cannot turn on with battery only when i pressed power button blinks then stops.but when i plugged charger only and battery plugged in it boots fine and no problem.Anyone can help on this pleaseNever stop LEARNING because life never stops TEACHING!
