Delta DPS-286AP (RDENCA336WJQZ) Troubleshooting
    Re: Delta DPS-286AP (RDENCA336WJQZ) Troubleshooting
    I have attached a diagram that I modified from a previous version schematic that I believe represents the circuit of interest for this issue.
      Installed new L6562D which appears not to have been the issue. The waveform at the gate drive to the MOSFETS attached.
        Attached are the waveforms at the other pins.
          L6562 Internal diagram
            If picture 3 is pin 8 you have a problem.
              Hover over the picture and the description tells which pin it is. Pin 8 is not shown. It is a very clean 15VDC.
              I don't think the Gate drive is going high enough to turn the MOSFETs on. I'm thinking the other inputs are causing the gate drive to shut down. Need to study this part a little more to see exactly how the OVP works.
                  Is this the gate drive out of pin 7? it looks like it should be ok, but is it getting to the mosfet gates?
                    The waveform shown is at the gate of the MOSFETS.
                      That's around 7 volts peak, correct? that should turn on the fets, there are 6 resistors (or are they jumper wires?) on the source of Q7808, If resistors, are they ok? What about D7805 & D7806, something is stoping that pfc circuit from working, and it's not that complicated of a circuit. Something is causing it not to produce the 380vdc but not shorting the raw 160v.
                      Did you check if Q7601 & Q7602 are ok? I suspect if they were shorted you would not have the 160v raw B+ either.
                        That's around 7 volts peak, correct? that should turn on the fets, YES
                        6 in parallel - together they appear as about 1/2 OHM
                        What about D7805 & D7806, Both check good - had to take out of circuit to test
                        Did you check if Q7601 & Q7602 are ok? Not shorted - both check good.
                        What next?
                          The 6 parallel resistors are 0.51 Ohms each. I used a better meter and the combined resistance measures closer to 0.1 Ohms, but I don't think I can measure accurately enough to tell if one or more of them have opened. If one has opened, that could cause the chip to sense over-current prematurely and shut off the gate drive, but the resistors look good so I doubt that any of them are open.
                          The output gate drive seems low at 7v... from the spec sheet it looks it should be reaching VCC-2v under lighter loads, which would be near the clamp voltage of 12V. I am going to look closer at the pre-driver circuit to see what is loading the pin 7 output so much.
                              The 0.5Ω resistors will be fine, It would take both fets to short to open all of them, I would check R7823 that connects the CS to those resistors.
                              In the past I have seen where the source resistor(s) open and that blows the resistor that connects the CS pin, and without this feedback the ic would not startup.
                                R7823 is 10 OHMs and tests good. The waveform is at the CS pin 4.
                                    So the fets are trying to operate, otherwise there would be no waveform on the CS, I guess you could try lifting R7641, that would isolate the pfc output to the main supply.
                                      Good idea. Will try.
                                        I lifted R7641 and no changes, so it does not appear to be load related. I'm going take another reading across the current sense resistors with the scope and try to get the waveform in-sych with ZCD and CS. It looks like either the ZCD or CS inputs can reset the gate drive and perhaps that may be happening prematurely due to one of those inputs.
                                          Thanks everyone for your advise. This is just taking too long, so I am going to part this unit out. Anyone need any of the other boards?
