Re: Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
Nooooo ! I will buy it !
Do not trash it i will buy it !
Send me a pm !
Jumped the gun there a bit. Tv won't fit in the bin and Mrs has stopped nagging every 5 minutes..
Does seem a shame to get rid and really hope this is not a panel problem. Reason I say this is that all the voltages check out.
As the fault (8 flashes) points to ADRS fault) I checked the voltages onto 8 address boards, 4 on the top of the panel, 4 on
the bottom of the panel and they seem fine. The ribbons cables going to them seem fine.
Also, got to check if the x sustain (with the possibly incorrect silk screen) was put in by previos owner an may be wrong model board?
Its model number is ANP2195-A
Other than checking around where I have repaired already (check that the fets are being driven etc) I don't know where else
to check.
The faulty, fets might have burnt up a couple of their resistors etc. Have you checked their related smd components ?
Yes, I checked the gate resistors. The driver ics (sot23-6) we're checked for shorts to GND so far. I need to check with a scope to see if gates of Fets are being driven by drivers to test drivers properly.
I am suspecting bust panel because when I power up and screen comes on I get a faint buzz and then a power down 8 flash fault. Then if I unplug the top right and bottom right address board the buzz does not happen and I don't get an 8 flash error.
The screen would only be bust if its cracked though they really cant fail in any other way, is it cracked at all ?
Cant be the panel then, sounds like your control board isnt telling the Y drive to sustain properly. I had this with a Samsung guessing the shorted Ymain damaged the Control board and it was causing some weird things on the screen. Tom will be able to help you if you get a scope though.
unlikely, I don't see a Y-main easily damaging the control board.
Could be shorted address lines, will be failed panel usually if it gives 8 red flashes after brief image.
I dont personally think its the screen as if it was the Tv would not have worked in the first place but then the Y drive failed something else could have failed when the fets did.
Also you can actually see the shorted address lines inside the screen when its off, you will be able to see one of the wires in the scree shorting out to the one behind it. But the VERY VERY RARELY happens.
Nooooooo
Got an image of it possibly might be fixable ?
Sadly it probably isn't if it's the address lines. These are nice TVs, but good luck reattaching the cables with 4000+ drive lines (for just a 720p TV! a 1080p one has nearly 6000!)#
8G and 9G Kuros do occasionally have panel failures, but it's one of the more rare failure modes.
Thats real crap Ohh well good effort Niblettr always worth a try buddy
