thanks for the answer, this TV only turns on the backlight, without the image, I don't know if the panel firm is also needed, let me know. panel: ves315wndl-2d-n02
thank you
In the archive are 2 software. For 25Q16 and 25Q64. On the motherboard are 2 memories: 25Q16 and 25Q64. Each memory is written with the dedicated software.
1. What I posted contains soft bin for U10 and separately for U12
2. These software are written with the programmer
3. Writing can be done directly on the board using rt809h
4. Writing can be done directly on the board using ch341 and a special adapter
5. Writing can be done on the memories detached from the board.
YOU REQUESTED SOFTWARE FOR U12 MEMORY.
THESE BINS CANNOT BE WRITTEN ON MEMORIES DIRECTLY FROM THE STICK WITHOUT PROGRAMMER
1. Quello che ho pubblicato contiene un bin per U10 e separatamente per U12
2. Questi software sono scritti con il programmatore
3. La scrittura può essere effettuata direttamente sulla lavagna usando rt809h
4. La scrittura può essere effettuata direttamente sulla lavagna utilizzando ch341 e un adattatore speciale
5. La scrittura può essere fatta sui ricordi staccati dalla lavagna.
RICHIEDI IL SOFTWARE PER LA MEMORIA U12.
QUESTE SOFTWARE NON POSSONO ESSERE SCRITTE SUI MEMORIE DIRETTAMENTE DAL STICK SENZA PROGRAMMATORE
What's so complicated?
1. Read what is written on memory U12: 25Q16 (2Mb) or 25Q64 (8Mb)
2. Save what I posted above (# 13)
3. Unzip
4. You have there bin for 25Q16 and 25Q64.
5. Rewrite the memory with the respective bin. It is advisable to rewrite both memories.
This is the last time I post here.
