help me dell 7320-7420 PASS
    Re: help me dell 7320-7420 PASS
    Originally posted by Vesko356 View Post
    It's under warranty. Contact Dell Support for assistance with proof of purchase.
    Actually I've managed to modify the bios to clean the lock but I don't know exactly how. Very strange.
      Thank you for the file, Unfortunately while soldering to the board I shifted few components and laptop won't power on anymore even bios and components are soldered back.
      I have got one more laptop with identical motherboard (Dell Latitude 7320). Could you pls unlock the dump file attached for me? I have a private repair shop and learning the stuff. What method you use to clear the pass? Are you able to find it inside the file? You are my saviour with both cleared bioses. Thank you again in advance.
        Dell Latitude 7320
        Become a Badcaps supporter
        Thanks to all supporters.
          Thank you. I programmed the data to the chip and soldered back. Now I can't see any light on and measuring the bios chip pins voltage has changed to 1.8v instead 3.3 Does it needs to be activated somehow or I burned something out again? Thank you for help.
            What ? How can it change from 3.3 vol to 1.8 vol ? What's code name of chip ? Just to be sure on first boot you have to go into bios settings to disable all security options.
              The voltage changed on the 7420 motherboard as well. It looks like I burned something out but I just soldered the chip with hot gun.I am getting this values on bios chip (Winbond 25R2S6JVEN)
              Pin 1 - 1.3V
              Pin 2 - 1.9V
              Pin 3 - 1.9V
              Pni 4 - 0V
              Pin 5 1.3V
              Pin 6 - 1.9V
              Pni 7 - 0V
              Pin 8 - 0V
                As far as I know pin number 8 must have 3.3 volts.
                  I found out the voltage is ok when chip is de-soldered. Once soldered back the voltage drops down as mentioned. Any idea why this behavior?
                    Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                      Try & leave feedback:
                      Good day, can you assist with the BIOS password for suffix 8FC8
                      Dell Latitude 7420 Board number GDC31 LA-K371P
                      BIOS BIN Below
                        BIOS BIN Below
                        Unlocked
                          Originally posted by hoaca388 View Post
                          Unlocked
                          Wow, it worked now I can change settings on the BIOS dude you are a genius I wish I knew how to do it so that I can help others on the badcaps forum.
                            Re: Dell Latitude 7400 Bios Password
                            can you help me? I do not know exactly which chip to read and where to find it.
                            I read this one out but the file is only 1MB. Can this be correct?
                            I have a Latitude 7420 2-in-1 (Not the one in the photo. I got the picture from the internet. But mine looks exactly the same.)
                              It is a winbond 25Q80DVSIG
                                Name of chips ?
                                  Name of chips ?
                                  upper one: winbond 25R256JVEN
                                  lowwer one: XMCC QH128AHIG
                                    upper one: winbond 25R256JVEN = 32MB Data
                                    lowwer one: XMCC QH128AHIG = 16 MB data.
                                    Read Winbond chip.
                                      Hi to All friend's and expert teacher
                                      need Dell latitude 7420 #9P0R7M-8FC8 bios unlock code...
                                        You need to open laptop find bios chip read and post here.
                                          i have LOCKED bios dell 7420 HELP
