hp elitebook 850 g5 bios password
    service TAG : 5CG9048LMM
    thanks in advance.
    Re: plz bios password for hp 850-G5 i5-8th generation
    try...
    There are 10 types of people in the world. Those that understand binary and those that don't.
      hi . I need delete the password bios of a hp elitebook 850 g5 .
      thanks.
        Re: hp elitebook 850 g5 bios password
        thanks.
        check if you still have a bios chip (16MB), if you have it, rewrite with Q78_011200, and the 33MB one rewrite with Orig + Q78_011200, don't forget to copy the 16MB bios before writing and check it ...
          my bios is a :
          MX25L25673G
          I program it as you said?
          Thank you
            my bios is a :
            MX25L25673G
            Thank you
            there should be another 16 MB chip on the motherboard, check on both sides of the motherboard.
              thanks for answering me. So I have to find another chip to read it and send it to you again? Or can I use the copy of MX25L25673G
                yes ... see if you have another chip on the board ..
                  I already found it .It was covered under a sticker
                  it is a winbond 25q80. As soon as I read it, I upload it
                    this is the memory winbond w25q80 dump
                      write the MX25L25673G chip with Orig + 078_011200 and test ...
                        hp elitebook 850 g5 bios unlock
                        Hi guys
                        Can anyone clear the password from this for me please?
                          Re: hp elitebook 850 g5 bios unlock
                          try
                            HP Elitebook 850 G5 Bios Password removal
                            Hi
                            Could anyone remove the password from the attached bios dumps?. I have read the both the chips on the motherboard. Not sure if you need both.
                            Any help much appreciated.
                              Re: HP Elitebook 850 G5 Bios Password removal
                              Originally posted by Crizby View Post
                              Hi
                              try..
                                Thank for the files. I tried them but the laptop just has flashing power light ( the one by the charger input). The power button does nothing. I'm pretty sure I've soldered the chips back on right. Any suggestions?
                                I'm using a CH341A with 3V3 mod and NeoProgrammer.
                                  try..
                                    Hi. Thanks for posting the files but I after programming the chips and resoldering them the Caps Light & Num Lock light just flash and the laptop does not boot.
                                      Originally posted by peste View Post
                                      try..
                                      this bios and ec are working,
                                      bu I get security error .
                                      laptop does not start with original bios and ec.
                                      can you fix the original bios and/or ec?
                                        try..
