Toshiba C55 - da0blimb6f0 rev:f Schematic Needed
    Hello all guys,
    I want to download Toshiba C55 DA0BLIMB6F0 Rev:F Schematic Diagram.
    Laptop Power is ok but Display not showing anything. Reprogrammed the BIOS already but nothing changed.
    Please help me out. . . ..
    Re: Toshiba C55 - da0blimb6f0 rev:f Schematic Needed
    I think no one is helping out in this forum. . . So Sad
      not available
        anyone have account from here https://***********/threads/toshiba-...limb6e0.14532/
          I notice from other posts that Toshiba C55 , L50 and the L55 use the same motherboard p/n DA0BLIMB6F0 rev F. Has anyone seen this board used in other toshiba laptops? If someone has schematics for another laptop similar using the same motherboard could you please post.
            Originally posted by sonunigam
            Hello Guys,
            Please Upload Toshiba C55-B1069 DA0BLIMB6F0 Rev:F Schematic Diagram.
            The problem is no display. When i check Bios Voltages there are no voltages. Only 0.7 Volts. I don't know where to find those voltages, that's why i need schematic diagram. Please upload it.
            have you ruled out the problem? i mean did you connect your laptop to a known good power adapter? did you connect it to an external monitor via hdmi or vga cable? any led blinks or sound beep? have you re seat or clean the ram.
            Never stop LEARNING because life never stops TEACHING!
              try this...should same
                thanks
                  thank you
                    thanks
                      thank you
                        schematics which should have much more similarity
                          Quanta BLID is an Intel SoC board BD9 on the other hand is an AMD SoC one.
                            Thanks!
